MGS5 Locking Wheel Bolts
Alb
Moderator
Solutions
6
Gloucestershire driving an MGS5 LR Trophy
Just remembered that my MGS5 came with a set of locking bolts. Strangely, they were packed in with the tools so not actually fitted to the car. Haven't fitted them yet and have no particular intention to do so but have other owners got these fitted?
Are you 100% sure they were not fitted? Mine came with a bag of non-locking bolts . . the locking ones had been fitted and the non-locking ones put in a plastic bag with the tools - along with the locking lug nut adapter. I suspect the dealer (Arnold Clark) did this as part of their prep work.
Anyone know the size of the bolts as I too got a set of locking bolts and they weren't fitted, no brace in the tools compartment.
I tried my wife's Yaris brace but it is too big. Or failing that can someone link a brace on Halfords or somewhere else please.
TIA
Oh…. I was not aware that the S5 came with locking wheels 🛞 bolts ?.
Are these supplied with the car from the factory, or by the suppling dealer ?.
I would think it’s the factory, as I can’t see the dealer paying for them tbh 🤣.
I purchased and fitted them to my ZS EV and have now removed them.
I suspect they will be the same wheel bolts on the S5 🤷🏻.
TIA
Bolts on yours are M14 x 1.5
I like this from Halfords. Nice bit of extra leverage, if needed. You will use the 17mm hex socket. You can get them cheaper than Halfords, though.
If you are thinking about fitting locking wheel bolts, I honestly wouldn't bother.
TIA
The standard wheel brace on most cars are a bit small and therefore requires a lots of effort to undo the bolts.
Can I suggest you go for one of the telescopic ones for better leverage.
It comes with a double sided socket of 17 and 19mm.
The locking bolts on the previous models are sized at 17mm and I would suspect that the S5 will be the same.
He is a bolt taken from my ZS EV.
To be fair, "fullness" depends as much on the size of the bag as the number of bolts.
I am away from home, so can't look.
I'm going to ask the dealer to fit them at the first service unless it needs to go in before hand.
My MG4 didn't have locking wheel nuts and I haven't seen any reports of their wheels being nicked so I'm not unduly worried.
It’s strange that they have suddenly decided to supply / fit locking wheel bolts on the S5 model now, considering that when the original ZS EV exclusive was released, it had diamond cut alloys installed as standard equipment, surly more attractive as sellable items by the pond life, you would have thought ?.
If you wanted protection from locking wheel bolts back then, they were sold as an accessory by MG - was that the reasoning ?.
The alloys installed on later models are pretty standard fair tbh nothing really fancy, then covered by a plastic wheel trim, but now have locking wheel 🛞 bolts as standard on the S5 ?.
A bit late to the party here I think 🤔.
