Jto
Is there any one who has a EV car and use electric storage heaters to heat there home.
Before you moved from economy 7 to Agile how was your storage heaters controlled?
Did you have a smart meter with two feeds from the meter to two fuse boxes, one for all circuits on day rate.
The second feed would go to a second fuse box for heaters and water storage heater and this would be controlled by the smart meter timer which would turn on the power at the off peak times To this fuse box.
Now if you are on Agile was there any modification needed to be done when you moved over.
A quick brief, family member had very old storage heaters on a pay as you go meter, changed this to a smart meter, after this had new storage heaters fitted and the power to heat them at night still come on between 1 am and 7am controlled by The smart as before, so if you move over the Agile would the off peak circuit still work the same way.
I help them monitor there electricity use and I see that Agile could be the best for them as electric and water is the only supply’s to property So very heavy user of electric.
