Parking Brake Mishap
Aitch1
Warrington
MG3 Hybrid+
I experienced an odd incident with the parking brake yesterday. While stopped at a 'lights-controlled' roundabout, for some unknown reason, I pressed the centre parking button instead of relying on auto-hold, as I usually do. This action disengaged the drive and, despite the frenzied cacaphony of horns blaring out, (why do they do that?), I couldn't engage Drive or Neutral. I switch the engine off and on and still failed to engage Drive. I still don't know how I eventually managed it, but thankfully I did, to the relief of the cars behind me. Any ideas or similar incidents from anyone? Aitch
I would think all you had to do was to press the brake pedal, then select D, and you'd be on your way, but logic tends to go out the window in a panic situation with horns blaring all around you. :confused:
Similar thing happened to me on a car park i forgot to hold the brake pedal done before pressing the start button i tried to select drive and reverse and it reverted to neutral not thinking logically i thought there was something up with the gearbox I switched the ignition off and realized what I had done
