andrewjoseph
I've done a quick search but can't find the answer.
How many miles left when fuel warning light comes on?
thanks
thanks
Mine seems to active between 70 and 80 miles remainingI've done a quick search but can't find the answer.
thanks
Thank you. We did a test drive last week and the car had 70 miles reported in tank. We had bings and bongs going off all over the place, it was raining heavily and didn't know what was what.Mine seems to active between 70 and 80 miles remaining
hence the question.Should always fill up before light comes on fuel tank will be full of sediment and debris which could end up in the fuel injection system could do yourself more damage ?
Fortunately, the MG3 has a fuel filter (integrated into the fuel pump assembly in the fuel tank).Should always fill up before light comes on fuel tank will be full of sediment and debris which could end up in the fuel injection system could do yourself more damage ?
Sediment builds up through time your integrated filter in the pump won't save you, could end up with misfiring hesitation difficulty starting the car etc , my advice would never run the fuel tank that low , only my adviceFortunately, the MG3 has a fuel filter (integrated into the fuel pump assembly in the fuel tank).![]()
