Power on but without options
ronald hogenboom
Curacao
ZS EV
Every time when I switch on my car, a lot of safety options are automatically switched off. So, if I want, I must switch on these functions every time.
Also the radio is switched off every time.
Why? and how can I switch them on "for ever"?
Every time when I switch on mine car, a lot of safety options are automatically switched off. So, if I want, I must switch on these functions every time.
what is your model and year?
which functions, list them one by one and we can try to help. Radio switches off when you lock the car, not much of a problem turning it on again... mine starts again when I turn the car on...
Upvote 0
I have a MG ZS EV from 2024, at least that is what my car-info tells me.
When I switch on the function "front collision assistant", it is switched off even when I had it switched on before. That is also with my radio.
Anyhow there are software bugs. Sometime it doesn't want to go into drive (or reverse) when I dont use my belt, and sometimes it is ok with that. Funny.
But what can I do to the first two mentioned points?
Upvote 0
I have a MG ZS EV from 2024, at least that is what mine car-info tells me.
When i switch-on the function "front collision assistent" is switched off even when i had it switch on before. That is also with mi radio.
Anyhow there are software bugs. Somtime he don't want to go in drive (or reverse) when i dont use mine belt and sometimes he is ok with that. Funny.
But whst can i do to the first two mentioned points?
What about radio? You just turn it on or off ... As to front collision assist, how do you know it's turned off? It works when it has to. Mine brakes suddenly if it thinks I'm going to slam into something...
Upvote 0
Radio is playing when i switch the car off. Then off-course the radio also stop. Then i switch back on the car and i must manual switching on the radio.
And the front collision assistant shows me a orange sign on the display (two cars in a collision....) and also when i go into the menu it is switched off. When i switch it on it stays on only until I switch off the car.
Upvote 0
And the front collision assistant shows me an orange sign on the display (two cars in a collision....) and also when i go into the menu it is switched off. When i switch it on it stays on only until I switch off the car.
That’s exactly what my radio does, think it’s supposed to do that. I like it that anyway regardless.
Upvote 0
Took delivery of the ZS in December and have found the radio does not switch on at startup at least 60% of the time, have to hit the mute button to get it going, dealership say they can’t make it do it but I think I’m being fobbed off. Have opened a poll to find out how common this is before going back to dealership!
Upvote 0
Hopefully this response goes through, I’ve just made an account after reading for ages because I’ve had this before.
The dealer I picked the car up from sorted it by reprogramming some number of modules, sadly I can’t remember which. It is definitely worth getting them to address it, especially given how simple it was to fix in the end (for the dealer at least).
Upvote 0
