I don't think any YouTuber has ever influenced me. The tag seems a bit of a misnomer to me. :)
I'm not sure they have to influence every single person.
But if they have influenced no one then it would indeed render the name a little silly.
For those following this story and initial reactions to it...
Another You Tuber (who is pretty knowledgeable) has produced a video after interviewing the company at the CES where they made the announcement.
Loads of people are now making videos about this and I haven't seen any of the others.
Yes it would be absolutely great if it is true.
The more battery options the better, particularly if they are much better for the same cost as this one is claimed to be.
Plus if it uses different materials to the other types of battery then it is good environmentally and geopolitically as well.
The problem is, the modern cycle testing methods. A heap of rapid charge and discharge, maybe 500 cycles or 1,000 cycles, measure the degradation and extrapolate a cycle life down to .... what ever capacity the manufacturer wants really, they are paying for the testing after all, so down to acceptable Lead Acid battery standards of 60% capacity and drawn down to 9.5v using the lead acid C20 test rate ...... probably could achieve 100,000 cycles ..... if that were possible inside the general 10 yr capacitor calendar life ...... that's 2.75 full chargers and discharges, every day, not possible at a C20 rate .... even back to back with no rest between cycles, that would require a C4 load and charge rate, even the little 51kw battery in our MG4, that's roughly a 35 amp load or 13kw, and a 14kw charge rate .....
T1 Terry
