stevedee
Bognor
MGS5
I hadn't appreciated until recently (...because I'm a bit slow on the up-take) that there were significant differences between the ev traction batteries for standard & Long Range S5 models.
So I put this table together...
Feature or characteristicLFP batteryNMC battery
CostLowerHigher
Cycle lifeHigher (maybe 2 or 3 times NMC)Lower (~1,000–2,000 cycles)
Range (per kWh)LowerHigher
Usage best practiceUrban: great for daily use & deep cyclingIdeal if you often need longer range
Safety / thermal stabilityVery goodGood, but slightly more thermal sensitivity
Daily charge limit100% OK70–80% best
Full chargesEncouraged: frequent 100 % SOCOccasional: 100 % SOC can stress cells
Cold chargingWeakBetter
Healthy’ battery range20 – 100% SoC40 – 80% SoC
This has an impact on how the 2 variants should be charged for best performance.
My full notes are here: MG S5ev: battery matters
I've noticed there is a third battery option shown in the manual. It is fitted in the 125 kW motor version normally with the 49kWh battery, and is rated at 62kWh, both LFP?
Separately there is then the 170 kW motor with the 64kWh battery, presumably NMC.
It doesn't quote the market for the 62kWh battery......does anybody know?
NMC (Nickel Manganese Cobalt) batteries typically have a higher energy density and thus a greater range per kilowatt-hour (kWh) compared to LFP (Lithium Iron Phosphate) batteries.
So, in the plethora of "how many miles per kWh?" threads we should be mentioning battery chemistry as a metric?
Let's look at this on a different logistics level. The 20% to 80% SOC of the NMC cells means the real capacity is 51kWh , the useable range of an LFP cell is not down to 20%, it is down to zero % SOC, not the 20% mentioned.
There is a point that needs to be made clear, so there is no misunderstanding. SOC (State of Charge) is from fully charged to all that capacity used, this is not down to 0vdc, the LFP cell will still be at 3 lVDC or higher, the NMC 0% SoC is 2.5 VDC. So neither cell/battery chemistry is down to 0 VDC @ 0% SoC.
Now, we have two chemistries that can deliver 51kWh within their cycle life maximised charging regime.
What about the weight between the battery packs? Using the same 51kWh as the capacity .... are NMC batteries really lighter?
Yes, you can get the first cycle with and NMC chemistry to deliver an additional 20% capacity .... but if you want to retain the cycle life, that means charging the last 20% capacity into the cell, just before you leave ...... does that fit in with the cheaper power window many use, or will this last 20% cost quite a bit more? How much further distance will that extra 20% give you? Does that match you bladder and coffee range?
The thermal operating range. If you live where it's cold enough to be even considered, you already use battery heating, so this part is just fluff really .....
With this information in hand, and the fact that China has virtually banned the NMC chemistry, so who will the manufacturer be ...... Which battery chemistry is the better choice?
Just to throw a spanner in the works, Sodium ion (Na+) is a real time consideration now, CATL are actually supplying manufacturers now .... so, a cheaper longer cycle life chemistry than either of the others and no need for battery heating because they are way ahead of either of the other two regarding low temp performance .....
T1 Terry
It looks like it's the same as the 49kWh, 125kW with 250Nm of torque but with a WLTP of 425km instead of a WLTP of 335km
Seems some bistro maths must have been involved in arriving at the 425km .... WLTP, What Lies To Publish, about the only explanation for such an unrealistic figure ..... Our poverty pack 51 gets 320kms on a good day, so the 335 is sort of believable if you allow for multiplying by the page number .......
T1 Terry
Aren't page numbers integers?
Had to Google that to make sure I had the meaning correct .... and for once I was right ..... If I'd asked the wife, the best I could have expected would be "correct" Not much hope of ever being right .... but if it ever happens, I'll be telling everyone :LOL:
Back to the question ..... I no understand of what you speak ...... what difference does whole numbers make to the methodology of how they came up with the unbelievable range numbers?
T1 Terry
