ZapMap should show all chargers so podpoint ones should be there. After going into several map apps I noticed that there are some rapid chargers around. Specifically Harrogate Civic Centre has some 50kW Genipoints. There is also a Gridserve Charging Station at the Wetherby Moto on the A1(M) with many fast chargers. So its not as bad as I thought.
However, using ZaoMap to plan a journey on a PC is very poor. If you set a filter for charger power it seems to ignore a lot that are pretty close to route. Even increasing the search radius seems to not show up these chargers. Also I notice you cannot, unless I'm missing something, select starting or finishing locations by clicking on the map locations. You have to enter the start and destination by text which is poor for modern apps.
I also looked at Google maps, which I didn't realize had the option in routing for showing EV chargers. This shows all those chargers above but I don't know how accurate availability is.
Can you enter your car details for battery rate at distances along the route though?
evcog
