Replacement Tyres for Cyberster GT
CyberNewbie
Peak District, UK
Cyberster
Sadly, I think I have a puncture in a rear tyre. As it has not done many miles I will only replace the affected tyre. I want to get the exact same tyre, a Pirelli P Zero 275/35 R20 102W.
There seem to a lot of Pirelli P Zero tyres, am I correct in assuming it is the P ZERO™ WINTER 2 that I need? I got the list of tyres from the Pirelli web site after using the Select a vehicle option.
EDIT: I had assumed the car came with summer tyres.
I don’t think it has winter rated tyres. There is a picture of a mountain on tyres that are ice rated.
Check with your supplier you may need to replace both tyres on the same axel if you have done a certain amount of miles.
I have done less than 1,000 miles so should be OK.
If you look on the Pirelli web site it is only the winter tyres that have a W rating.
I found 2 different types, with EAN numbers 8019227393989 and 8019227278248.
Pirelli P Zero PZ4 275/35 R20 102Y XL
Pirelli P Zero PZ4 Sport 275/35 R20 102Y XL F ZR
