AllanO
I had a Rolec Homestart EV charger installed 2 years ago when I bought my HS PHEV as part of the deal between MG and Rolec that was available then. I live in a rural location and when installer was fitting the charger he told me that my mobile signal was not good enough to guarantee reliable working of the SMART function of the charger. He said that the mobile network signal was constantly improving and that function should improve over time. The charger worked reasonably well for the first 18 months albeit requiring rebooting fairly regularly but latterly the device will sometimes need 4-5 attempts to reboot successfully or lose network connection whilst plugged in. I usually charge on an off peak Economy 7 tariff and this means that sometimes charging occurs on peak rate. The EV technicians have tried to improve things by blocking certain mobile networks but this made things worse. For those who don't know the Homesmart Sim works on the 2G network and tries to connect to one of three networks. It currently connects to EE which is the best signal locally. It has been suggested that a mobile signal booster might improve things. EV couldn't help on this saying they only deal with software and suggested I contact the original installer or ROLEC for hardware issues. I don't know whether a commercially available mobile signal booster would suffice or whether a specific Rolec component , if available , would be needed. Rolec have yet to reply. There are several dual/tri-band static indoor repeaters available for between £300-400. Installing a new charger would cost around £1000 so a booster may be a cheaper option if it works. I note that the latest Rolec homechargers now run on 4G and also have a WiFi option. My charger is fixed some distance from my Internet hub and I don't know how reliable a Wi FI connected charger would be. Has anyone out there had similar issues and if so how have you been able to correct things?
