Sat nav
Kpa
Bolton
Can’t find a way to put postcode in the sat nav? Anyone have this issue?
Do you mean the std MG satnav? If so - from home screen of satnav click bottom right corner - next screen click new address - next screen I think it’s second field down where it says town or postcode you can input a postcode
ISTR it was a bit tricky, can't remember why now though.
Was it the bit where you either have to put a space in the postcode or don't have to put a space in ?
Yes you’re right, you must insert a space as appropriate, If you do it works fine - keys are a bit laggy and weird but you do get used to them
Yes it does. It’s actually not that bad if you persevere with it. Using Apple carplay is a better overall experience though I find.
