Steering
RoadUser
Berkshire, UK
I've noticed this I picked up the car a month ago that the steering feels a bit loose when turning left than right and also at times it feels like you have the steering turned in one direction a bit and the car is going another way. Is this normal for this car or does it need an alignment done?
Another thing when walking towards the car, it appears the front wheels don't seem level like other cars but a bit angled in like ( \ / ). Anyone noticed that or is it just mine!
You should not really require an alignment check on a car that new, unless you have had an incident where you have hit / contacted a high curb or alike ?.
The regards to the second thing in your post :-
Which relates to the angle of the front wheels ?.
This is the camber angle of the front wheels and therefore forms part of the steering geometry of the car.
The symbol your have shown in your post, indicates a car with a positive chamber on the front wheels.
A negative chamber is the complete opposite of this symbol that you have illustrated.
If you are worried about the safety of your car, I would have the dealer check it over.
Abnormal tyre wear quickly develops when the steering geometry is in any way out of wack.
Does sound like it may have taken a knock or, if not, maybe just badly set up in the factory (pretty unlikely) or even knocked in the process of the car being delivered to the dealer? I'd definitely get it looked at, ideally by the supplying dealer. Good luck.
It might (sounds counter intuitive) be rear wheel pressures out or, something not quite aligned. Can make a fair difference to the front end.
The front wheels should have 7 minutes of negative camber so from a visual perspective they will look vertical.
I got my ZS EV last March 2020 and had to take it back because it was pulling to the middle of the road. Turned out the tracking was out of alignment quite a bit. So being a new car doesn't necessarily mean the wheels are right.
That's disappointing. You'd think they would have these kind of things spot on with a new car wouldn't you? Maybe the cars get knocked about in transport from the factory to the dealers?
I had to get my Tesla steering wheel straightened when new as it was not straight when driving a straight line. The car had a geometry check done too.
Thanks for all the replies.
I'll check the rear pressures and see, as that appears to be a quick fix if worked.
The dealer I got the car from isn't local to me, so will have to go to a local one and see if they'll take a look; I take it if the alignment is deemed incorrectly done when delivered it would be sorted under warranty by any MG dealer?
Saying that do the dealer workshops have the equipment to do the alignment or do they send it elsewhere?
I'd ring the MG dealer you are intending to use and tell them that you have got a new MG which appears to have a steering issue. Would they take a look to confirm and then specifically ask them if any steering alignment adjustment that may be necessary would be covered under warranty. Most importantly, tell them it's had the problem since you took delivery.
When you driving down a straight road, is the steering wheel, slightly off centre to the central position?.
Therefore when you try and correct it with your hands, does this feel like the car is drifting towards the centre of the road or towards the kerb ?.
This will give you a strange feeling that you are fighting against the car wanting to take you in a different direction, than that indicated by the steering wheel.
If this is the case, then when the car had the wheel alignment check done at the factory, the steering wheel was NOT set in the dead straight ahead position first.
So when you are driving along a straight road, you are constantly trying to correct the error displayed by the off centre steering wheel with your hands.
Does that make sense ?.
Your mind can not deal with driving a car that is set up this way, and constantly you are trying to correct the error, which sends you off course.
The wheels maybe aligned correctly with regards to the steering geometry and running parallel when it is driving down the road, but it has been set incorrect to the steering wheel alignment.
If so, it will just need the steering wheel set in the correct straight ahead position FIRST - then the wheel alignment reset to the correct level of toe in / toe out recommended by the manufacture.
Very unlikely, but the steering column has been attached to the steering rack one spline out of the correct position when it was assembled at the factory.
I doubt this as most have a master spline now.
Just to be clear here, the tracking of a car does not just “Go Out” as some garages will have you believe, when they want you to pay to have it corrected.
The so called “Tracking” or correctly put, the wheel alignment will only report out in mainly under the following conditions.
1) It was incorrectly set the last time it was “So Called” adjusted.
Usually caused by operators error.
2) There is wear in one or multiple components of the cars suspension system ( older cars ).
Worn track rods ends, ball joint wear or suspension bushes or components.
3) The car has suffer and impact with something really hard, like a huge pot hole or had a very hard side impact with high kerb etc.
But we are talking about a HARD impact here, not a just wheel scrap along the kerb.
Rather like something that is capable of bending one of the steering / suspension components.
When the steering alignment is set correctly it will remain correct, until one of the above situation should arise.
If you are witnessing uneven tyre wear on a pretty new vehicle, then the likelihood is the wheel alignment was never set 100% correct at the factory.
Wheel alignment is an easy function to perform, BUT only when it is done correctly.
I have correctly reset the wheel alignment on SO many cars that I have lost count.
Some of the things I have seen over the years would shock most people.
If you are told :- “Hey mate you need your tracking resetting, do you want us to do it, we are doing it on a deal with your new tyres”.
I advise caution ⚠️.
Take it to somebody who only specialises in four wheel wheel alignment and has been doing it for many years.
Buy cheap, buy twice !.
Otherwise you could be replacing your new tyres before to long.
When I got my new car everything seemed ok. The steering wheel was pointing straight but we have a tram service in Sheffield and I wondered if it was the tram track that was making it wander to the middle of the road. But then I noticed that it was doing it on other roads as well. All I was doing was correcting the steering all the time. So I took it back to the dealer and sure enough they said that the front wheels were way out of alignment. Thankfully they fixed it and the car is great now. But it's the last thing you would be looking for on a brand new car. The work was done under the warranty.
After trying various options before taking it to the dealer, one thing I've noticed the steering handles better in normal mode than eco.
Another thing i've come across is the driver side wiper makes a strange noise during operation (i.e. not the usual), if it has been raining for a while. Like if I've been driving and the rain has been persistent for a while, or if I start the car after it has been raining for while, never heard this type of change in an ICE car, but then the engines were loud!
"Back in the day" - Checking the tracking ( wheel alignment ) was part of the PDI inspection.
It looks very much like that has been discontinued now !.
Here is a table with details of warranty. Wheel alignment is 3 months/1000miles.
Sorry for you guys with this warranty. In Norway we have 7 years 150000km. Of course not on brake pads, wiper blades brake pads and other consumables, but the rest is covered. May be our warranty is due to the price. We paid around £ 27000 for our car back in 2019. All cars in Norway has 5 years 100000km at least. MG and a few other has 7 years 150000km. Which is great since the dealers charge £ 150 per hour repairing the car. An annual maintenance is £ 350 to 600.
Think you'll find that what they told the receptionist to tell you. More likely its psychological and it's the placebo affect that's sorted the 'problem'
