Darkside
North Yorkshire
HS Hybrid+
Does anyone know if there is a way to reset after inflating? Clearly has tyre pressure monitoring as they show on the ‘flow’ information screen on the right side of the dash. I’ve not needed to inflate yet but every other car we have owned needs resetting after inflating so as to warn if the pressure drops. Cannot find in the manual (unsurprisingly 😂) nor in the menus/sub menus
It kind of resets itself after driving a few miles, for example, if one of the tyre pressures is showing low on your display, inflate the tyre to the pressure you want, then drive the car as normal, and the pressure will eventually show the correct pressure on the screen. There is no way to manually reset or change the pressures.
Great stuff - thanks for swift reply - never had a system like that but sounds simpler than normal so all good 👍
