Yeah, that's what's on the NZ video. But I can't find it at all on my car. That screen has only the Next Service option. I wonder what would happen if you combine a setting on that with the % overspeed threshold setting in the Navigation section (assuming you have that available, which I do).
Hopefully you won't see much use for it if you keep it at that level 😂
I'm not sure it's the camera that triggers it, I believe it's the satnav. But I may be wrong. The SE version doesn't have the front camera does it, but I expect it has the speed limit warning? (I'm not directing that question at you Andrew, as you have the Trophy, like me.)
I tried several settings of both threshold systems together and seperately. doesn't make a blind bit of difference as far as I can tell. I have the threshold set to 'off' as I said earlier, only at that setting while I took the photo to show max available.
