Wireless connections
Aitch1
Warrington
MG3 Hybrid+
Does anyone know if it is possible to use a USB dual 'splitter', or whatever it's called, to connect my usb stick with music, and automatically connect my android phone?
Hi, I tried to do exactly this and it does not work, what did work though is you can plug your usb stick into the C port and the music is recognised after waiting a short while. You would need a USB A to C converter or alternatively a dedicated USB C memeory stick.
Hope this helps you.
Thank you, I'll give it a try.
That is good to know. My car is on order with Mobility still but according to the brochure and the Dealers that USB C connection is power only.
Nah - you can play most entertainment stuff from your phone via carplay as well when you plug in 👍
I have a USB stick connected to the USB-C socket, via an adapter, and a wireless carplay adapter is plugged into the other USB slot that connects to an iphone. I find this works perfectly.
Hi there;
I use this:
And this:
John. Just to clarify, is the USB stick connected to the right hand socket? Only I thought that socket was for charging the phone. Also, could you tell me the make/model of the carplay adapter you are using, and will it work with my android phone? Cheers
