10mm spanner fix - How often do you need to apply it?
  • More than once a week
    Votes: 0 0.0%
  • More than once a month
    Votes: 0 0.0%
  • Total voters
    28
mrg9999
Slough
How many times do you have to apply the 10mm remove negative lead fix to make you MG ZS starting working like a proper car again.
I've had
parked car, come back - nothing works. 10mm spanner, everything works.
First time this happened in 2023 I called the breakdown, the chap did some basics ODB test, then opened bonnet, disconnected batter neg lead and went to make a cup of tea. 10 mins later reconnected and everything worked.
After pushing the home button and resetting the spanner is my most common fix.
1 More than once a week
2 more than once a month
3 Occasionally
4 Never
Haven't got my MG yet but I own a 2022 Morgan & it has done that. The Morgan dealer mechanic said it is quite common with the BMW ECU / BCU & engine.
I found one lead wasn't totally tight so with the -ve off I would tighten the +ve.
I have an MG5, pre-facelift, but I've never needed to remove the 12V battery negative lead.
I have an MG4 not a ZS, but ... I've never needed to touch the 12V battery terminals. 🤷‍♂️
Thanks, someone else said their MG4 has never done it either.
I have an MG5, pre-facelift, but I've never needed to remove the 12v battery negative lead.
It seems to only be the ZS 2021/2022 models
I have used the 10mm 5-6 times on my MG5 SR Excite. Either to clear the Radio Module Disconnected fault or after getting bricked on a CPS charger.
I think twice in the ZS. I can’t think I needed it over the three years / 33000 miles in the brilliant five. A month or so / 1500 miles in the Citroen e Berlingo and no faults.
I don't know if this 10mm spanner fix only applies to the MG ZS @mrg9999 , but this poll doesn't, there are already several votes from other MG model owners, so unfortunately the result won't represent the MG ZS problem.
I posted a reply but I did not cast a vote.
Same here, but out of the 12 votes cast so far, probably only a couple are from ZS owners. It doesn't really matter, but if the op wanted to know how many ZS owners had this problem, this poll isn't going to help him. ;)
In 4 years never. Currently in Edinburgh and at ionity carlisle i got a hv faultwhen restarting the car :eek:
Dug the 10mm spanner out and disconnected for 5 minutes.
The journey continued it's safe to say
We owned both ZS EV models.
The original Gen1 for just under two year and the second Gen2 for just over three years.
Both where early launch cars.
They covered roughly 28,000 miles each.
Never conducted a 12 volt reset on either.
The majority of 12 volt resets problems, were found to happen after using a rapid chargers.
If I remember correctly, both models received software updates for after charging issues.
Twice in 4 years, both times because an older charger messed up and caused the car to 'fault'. The first time it didn't work and I had to call the AA who reset it via the obd2..
I have used it once only in 2 years.
Car was refusing to charge on DC chargers, used the 10mm spanner and no problems since then.
ZS EV 2021
I know I've used it, but was that to correct a problem or just be on the safe side while we parked it at the airport for a few weeks?????
I have a feeling it was at the airport, but this old brain can never be sure about things several months old.
