Ive been wondering about the battery chemistry of the Xpower. I am not sure MG would slap a 7 year cover on the battery from the standard 64 MG. Pulling double the amps ! has anyone any detail on the battery ?
I'd be surprised if the 64kWh battery pack was different in the XPower ... I reckon the pack is easily capable of coping with the XPower load (remembering that it is peak power that is drawn, not constant power - the car will throttle back power if the battery temperature rises too much), and that in the LR models it is not being taxed.
It is the same pack and same cooling system. Unfortunately they did not uprate the cooling, which you'd need for track work. But then few people ever go to a track, so it does make some sense.
Building a battery to support 320kw or building a battery for 150kw , its not just heat, higher performance batteries cost. Id say same shell and cooling, bigger copper busbars, bigger fuse, bigger relays - and possibly different cathode and annode materials to support the small amount of xpower MG4s. Or MG are taking a gamble on how they abuse the cells.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
