ACC going off suddenly.
Chrisd
Uk
Has anyone else an episode when the ACC (and associated systems) suddenly stopped working ( I can't remember the exact warning) mid journey then coma back on a hour or so later? It's happened occasionally when starting the car I've just restarted and its been fine, but this is the first whilst driving.
Haven't had this one, but the speed limiter stoppted working once whilst driving.
Many of the systems are tied into the infotainment,
If you reset that, the car will panic.
I did this once, while driving and as soon as the radio screen turned blank, the car threw a gazillion warnings about systems being inoperable. Came back when the radio had rebooted
It has happened in my Kona when "ACC conditions not met". I think if the system gets garbled data from the radar and/or cameras it deactivates and defers control to the driver.
I thought it was Adaptive Cruise Control?
The confusion probably stems from the fact that some cars have used the term ECC (Electronic Climate Control).
I once owned a vauxhall Zafira, and the climate control was called ECC, because it was "electronically controlled", and the temperature and whatnot was electronically displayed.
Nowadays this term has become a bit redundant because "all" new cars with climate control has this feature.
It can also stem from the fact that ACC also use to mean "Automatic Climate Control"
My remote garage door opener will often cause the radio to turn off- on the way home, not on the way out!
