Hi, what is a trunk? Do you mean the US term for the rear storage area (a boot in the uk?) or the front bonnet (hood in the US?) where you can store small things and buy an frunk box?
With a power supply you need to think about whether you want it permanently live, or controlled on/off by the car key. The boot light is probably always live prior to the microswitch that goes on when opening the boot.
I'm not sure what the current capacity would be for a LED light circuit, I suspect low like 3A max, but the usual 12v 'cigarette lighter socket' can usually supply up to 10A from memory. So the socket couldn't supply a high power device, eg a vacuum cleaner, possibly not an electric cool box either. USB sockets can usually supply just over 2A from memory, possibly 3A for USB C.
So you could well be fitting sockets that could have devices wanting up to a total of 15A on a supply set to 3A max. It could also upset the canbus warnings if power is taken from a strange source.
