Air Conditioning Fan Speed
Alomaiyshi
Kingdom Saudi Arabia
Good day
I have a problem with the air conditioning fan speed does not change its speed and sometimes the fan works even if the air conditioning is turned off and I have to disconnect the battery finger until the fan stops for car MG5
We need your support
It is possible to contact via email
[email protected]
Thanks
Does it stop if you increase the temperature setting ?
Perhaps it is operating because the car's internal temperature is higher than you have set.
Does it turn off when you turn the heater/AC off by pressing the on/off button.
On the screen, it shows that the air conditioner and the compressor are working, but the fan and the compressor are not working, and sometimes the compressor works and the fan does not work, sometimes the fan works and stops
Disconnecting the electrical source of the connector to the air conditioner fan, the compressor works
2020 MG 5
SWMBO's 2020 MG5 has AUTO HVAC.
Bottom left button.
