Paulie68
- Aug 22, 2019
- Location
- North East Lincolnshire
- MG5 Trophy LR
You might remember my post about play in my steering column from a while ago. well it got gradually worse until it could be moved up and down about 5mm.
Today, I had the plastic panels off to wire in my auto dimming mirror, and sort out the buzzy rattle from the A pillar cover, so had a good look at it whilst I was under the dash.
The height adjustment lock seemed the most obvious starting point, it seemed fine. I did tighten the nylock nut just a little to make sure, but there was no play from the lock mechanism.
After much searching I did find the causes, which were twofold, and the second part of the reason wasn't at all obvious to see! I suspect a lot more people will be getting this issue over the coming months as the mileage increases and the wheel gets pulled around. It'll be interesting to see how good the dealer technicians are at getting to the bottom of it.
The steering column is attached to a reinforcing bracket that is welded to the cross tube that runs the full width of the dash with 2 bolts. The bolts actually go through nylon inserts that sit between the two pieces of metal. Although the bolts were tight, the inserts seemed to have settled allowing play between the column and the cross tube bracket. Further tightening of these bolts removed this play. So for so good. I should have taken pictures, as that probably sounds as clear as mud, but forgot to!
This alone though only removed about half the play, something was clearly still not right. After much head scratching and staring at everything with a bright torch whilst pulling the wheel up and down, I realised the remaining movement was the cross tube under the dash itself flexing, even though it is solidly bolted at each end of the dash. Now, it shouldn't be able to do this, as it has a significant structure welded to it bracing it at the point above the steering column....
So, after suspecting a possible failed weld between this bracket and the cross tube and contorting myself into a pretzel under the dash area, EUREKA!! I found the issue. There was play between the support bracketry and the bulkhead itself. Again I should have taken pictures!
And here is the bolt that holds the bracket to the bulkhead. It wasn't very tight at all! Complete with its two QC paint marks! I suspect they are using too low a torque setting allowing it to work loose. Hidden away under the scuttle panel, It wasn't at all obvious where to find it initially!
Anyway, the wheel and column is as tight as a drum now
Don't know if this will also have cured the slight, random, clicking noise, as I've yet to road test...
