Mark and Bern
Annoying Alerts, how do we turn the beeping of?
Hope you can help?
			Hope you can help?
All good as we are just learning about our EV!!Annoying Alerts, how do we turn the beeping of?
Hope you can help?
Does the cruise control use more of the battery.
Whilst Cruise Control will use minimal power, sadly it doesn’t use regen braking and so will hit your range. I’m surprised it hasn’t been more of a topic for conversation on here, as it’s one of the shortcuts from ICE to EV I would have thought could be easily corrected.
I live at the top a long hill, so regen available with a full charge is great for me, it means after a mile I have same/more range than I started with.i’m on the 455v bms and when fully charged it’s only for a very short distance that regen is limited - no issue at all really. Those with the 450v bms have suggested when fully charged regen occurs sooner - but really i think that the difference must be minimal. The ACC hasn’t changed and still uses friction brakes to control going over the set speed not regen.
true no juice used, but because on the lower BMS 449/450v, it does have room for the regen to add more juice.That’s great. I have to say though if you start your drive going downhill fully charged regen or no regen you’ll still not use any juice to propel you along! And if you’re at fully voltage it won’t add over that amount will it?
Full regen comes back after 3 miles on mine.i’m on the 455v bms and when fully charged it’s only for a very short distance that regen is limited - no issue at all really. Those with the 450v bms have suggested when fully charged regen occurs sooner - but really i think that the difference must be minimal. The ACC hasn’t changed and still uses friction brakes to control going over the set speed not regen.
