Pauly
Most vehicles i have had in the past use either one press on keyfob or two depending if you want deadlocking or not
That's been the case with my previous vehicles, the ZS is the first one I've had that deadlocks automatically when you lock it with one press of the fob or door button.Most vehicles i have had in the past use either one press on keyfob or two depending if you want deadlocking or not
No, I did that, thinking I was deadlocking it, when I first got the car, the second press just unlocks the car.Perhaps two presses locks without deadlocks ?
Thats what my current VW does, will have to try and remember to try it out later when im home
Bmw do that as a safety feature not sure why to be honest people hate it in the back of mineThe passenger just has to double pull the door lever to open their side - the driver doesn’t necessarily have to do anything.
Im waiting on my ZS so currently driving a 2019 Focus. If I press the keyfob once it locks and i can still unlock from inside the car, but if I press the keyfob twice it deadlocks. My Wife's 2017 clio is the same, press 1 for lock, press 2 for deadlock. Would have thought the MG would be similar?AKA deadlocking.
It's to prevent someone breaking a window and opening the door with interior handle to get in, meaning they have to climb through the window to actually enter the car a slight deterrent to theft. IIRC it's a requirement in the UK for insurance purposes.
As you say, it is dangerous to lock someone in the car, that's why many manufacturers advise against it, although there's no mention in the ZS manual.
I may be missing something here, but surely if there are people left in the vehicle they should just lock it from the inside....I just tested this once and for all.
Got into the car, closed the door, and pressed LOCK on the keyfob.
There is good news and bad news.
The good news is that even when i lock the door, it is still possible to open the door from the inside, pulling twice....Pull-release-pull (Works on both front and rear doors, so nobody should be trapped inside)
The bad news is that when you lock the door, you arm the alarm, so anyone left in the car, that tries to get out, will trigger the alarm, and the person with the key has probably left so no way to turn the alarm off.
