Auto high beams
On the early 2CV’s the there was a lever inside the cabin, when you wanted a longer reach with the headlights, you just pulled the lever, which then was attached to a head light bar running through the engine bay.
(y) Citroën were also leaders with directional headlights on the DS...
I don't think it's right to say that the 2CV was a leader in this respect (much as I loved early Citroens, and the 2CV in particular).
The mechanically dipping headlight was a Cadillac invention as early as 1917. It was replaced by the Osram dual filament bulb in 1925, a much neater, better and cheaper solution which became standard until the 70s or 80s.
If Citroen put a mechanical dip on the 2CV (and that's not my memory, I think it had a lever to level the lamps when there were people in the back, but I may be wrong about very early ones) then it was a retrograde step.
By the time I drove a 2CV in 1974 (I'm not sure how old it was, but not very) the dipping mechanism was dual filament.
The S5 and my previous ZSEV auto headlights are terrible - just turn it off. They take about 2s or more to react (if they do at all) and just annoy everyone else on the road.
My previous car's headlights were utterly amazing (2015 Merc E220D cabriolet) with "intelligent LED Light System". It's not a simple dip/high, but the beam "shapes" round the vehicles in front, so the main beam stays on except in the bit cut out around either rear brake lights or oncoming headlights ahead and changes dynamically as it moves. The beam also tracks round corners, so when you're going round a right hand bend the beam swings right to illuminate the road you're heading onto. Everything happens in an instant, zero delay and I can never remember being flashed. I bought the car 2nd hand and didn't even notice the £2k+ optional extra on it, which turned out to be the best bit of tech on the car and I've never come across anything like it in any other car. There's a video here and here which gives a flavour but probably doesn't do it full justice.
I've had similar LED matrix lights on a Vauxhall and I found them excellent - I'll miss those, picking up MGS5 tomorrow..
It’s not terrible, it does actually work most of the time. You’ve just got to be aware of the limitations of it - looking around bends mainly.
It’s the same as most things that require any car to look ahead. They only seem to look in a straight line.
My previous car (Ioniq 5) also had similar shortcomings. There is a particular urban road I drive on most days where there is a slight bend and there is usually loads of parked cars. Every day the car thought I was heading straight for the cars parked just after the bend and triggered the collision detection. At least I don’t have that problem in the S5 😉
@Hugo A Go Go same here, slaps on the effing brakes every time, exactly the same on my previous MG4.
Our other car is a Hyundai Tucson (rare 4WD) it has a lovely lighting system, especially useful are the cornering lights, activated when turning at lower speeds and lights up the nearside kerb/verge area.
That is something I really miss having on the MGS5, sometimes at night wondering if I'm going to kerb the wheels because the nearside is in darkness, a great feature, probably only available on more expensive cars.
I'm pretty sure @Lovemyev was referring to the headlamp height adjustment - at least that's how I read it - he didn't mention "dipping" in his post 🤷‍♀️
I have s5se long range and I don’t seem to have the some of the issues that the trophy owners do, except the auto main beam which I have disabled. My wife’s Mokka is just as bad and I have turned that off also. It might be a good idea if we went back to a button on the floor. But most of you won’t remember those.
Oh yes I do! 😂😅🤣 @dicky ticker Dave , a lot of us old barstuards must remember that.
Put me on the list, I both remember and have used the “button on the floor” myself.
I had a 1960 forest green classic Mini that had it !.
I clearly recall removing it, when I upgraded the whole steering column assembly.
The later columns had the steering lock facility and dual switches for the indicators and wipers horn etc.
I had a red 1959 "Austin Seven" which was a very, very early Mini. My very first car. ** Sigh
It had a black roof, but I am not sure whether that was factory or painted later. We painted his name Борис Николаевич Лобачевский on the side. Oh, what japes. 🤣
Has this been tested on the latest software and does it make any difference? We had a loaner from MG on old software and I experienced all the issues reported here. We've just (finally) got our new car delivered and it is on newer software than I have seen mentioned on here....I wonder if it has improved (it is the wife's car so I have not had the chance to drive it yet)
