Montego
- May 11, 2023
- Basingstoke, UK
- Not an MG
Does your home charger automatically resume after a power cut? Mine (Pod-Point) doesn't. I have documented the on-going problems with the low voltage supply elsewhere ( Lowest Declared Voltage Tolerance and Charging ) But add in power cuts [not low voltage - no voltage!] and only one-third of the off-peak charging sessions this year have been successful. In that time we have had 3 power cuts (only 2 when charging). An unusually high number.
My expectation is that a charging session will resume once the power comes back on, allowing for a start delay to prevent a network surge . I did some research to see if other chargers are more tolerant and do resume after a power cut. The summary I got was: "Most modern, high-quality residential EV chargers, and many smart units, feature automatic restart capabilities, resuming charging after a power cut." The short list of chargers with automatic resume included Pod-Point (which I will have to take up with them).
We will be moving soon, hopefully, and I will be looking to purchase a new and more resilient charger. So my question to the learned folks on this forum is Does your home charger automatically resume after a power cut? And if so what is the make and model??
Thanks, M.
Thanks, M.
