Octopus Go Intelligent new 6 hours charging limit
Doesn't sound excessive to me - depends on how much you drive and/or use electricity around the house. Just checked... we're similar to @Tig170 having used 9.8MWh so far... but fortunately we generated 10.5MWh from solar in the year to date :)
We have oil heating but the rest is electric and 1.5 cars (only had 2nd one for 6 months) and around 8k miles each car. Our 4kW array has generated around 4mWh (on FiT) and we self consumed around 40% of that, that's why I need to investigate a battery to try and up that.
As a newcomer to EVs and this forum (but not to the world - clue's in my user name) I've waded through the whole of this lengthy and interesting thread and not really arrived at a solution to my problem. Background : wanting to do an equalisation charge on my MGS5. On Octopus IOG, with Hypervolt Pro3 wall charger; if you lived here and had a mobile phone you'd know why! We don't have solar because our roof faces east and west. I've no interest in 'gaming the system' - I just want, like most here I guess, to do my periodical 100% charge at minimum cost. So in words that an 'elderly person' with an electrical engineering degree from 55 years ago, never used in anger, and 30 years in IT almost all in Cobol programming on character based systems can understand : what is the most economical; setup for tonight's overnight charge? Battery is at 15%, it's a nominal 64kWh.
Help and advice will of course be appreciated.
I would do that on a granny lead once about 98% is reached.
Welcome to the forum @Old Codger, I bet you're not as old as your Avatar locomotive :)
Busted! I'm not far off though. But thank you for the welcome :)
I hadn't thought of that solution. It's expensive, since I don't have a granny lead and have so far only done 1400 miles and haven't needed to charge away from home. The longest journey so far has been about 170 miles, managed comfortably on 90% starting charge, and I've accepted the need to use public chargers (or trains - clue's in the avatar!) for the occasional longer trip. Usually I keep to 80%, one of the few bits of conventional wisdom which seems to be generally accepted. That said, I assume the logic is that a granny lead would guarantee a slow charge for the balancing bit?
I've been an EV driver for 10 years and travel abroad, as in the list below.
Public charging should be easy, just avoid British motorways during holiday / summer weekends!
Welcome!
So your 64kWh is about 61kWh usable capacity so if you need 85% to charge to 100% at the average (at car) 6.4kW wall charger you need about 8 hours 10 minutes plus balancing time, let's say 9h total.
With IOG you have 6 hours fixed hours at low rate plus whatever slots you get.
So for a normal balance to 100% I would just do a regular IOG charge and set the delta high enough to allow for some losses or if you have the target charge only, balance after it hits 100% using a bump charge.
If you are talking about a calibration charge when you want uninterrupted charging, IOG slots are no good to you, so you need to bump charge within two hours of the cheap rate: eg 9.30pm put it on a bump charge and it will charge until the car stops it, which will cost you 12.8kWh at day rate and 38.4kWh at night rate plus what is needed to finish and balance: say another 5kWh at your day rate.
I would say keep it simple. Doesn't matter what state of charge you start at just fully charge it to 100% and allow it finish in it's own time. Equalisation done.
Calibration charge is different and supposedly has to go from 10% ish to 100% in one straight charge. I have never done one in over 5 years of EV owning with 3 different cars and not doing so it has made no difference to range or battery health.
Keep to the 80% for normal day to day if you don't need any more but when you do just charge to 100%. The only real recommendation is don't leave it at 100% or very very low for any length of time otherwise charge it to what you want, when you want. There are many people that charge to 100% every night.
Public charging is not a problem, have a trial go at one locally just to get the hang of it. You don't need to spend a lot, just start it, give it a few seconds and then stop the charge. Job done and you know what to do on the road.
but as @EVsince2016 says
But that goes for any sane person driving any car. :)
Just enjoy the car and don't overthink the whole charging thing, it's just fuel you put in like any car. Long journeys are suddenly enjoyable in an EV and the short break for charging if needed after 1, 2 or 3 hours driving (it often isn't) is just an opportunity for cake and coffee and adds to the pleasure...after all we're not in a rush are we ???
Great post.
I have also never done a calibration charge and on my 3rd EV, same as you no issues with battery health or range, batteries are far more robust than initially reported.
Same as you I also do my equalisation charges from any range normally mid to high 20s or low 30s, no issues with NMC batteries, never had a car with LFP battery.
Enjoy your car👍
Pretty much exactly what I did in May before my Scotland trip, worked out fine.
My problem with this, is not the 6 hours of time limit but how it works with solar.
Currently when charging on solar, Octopus often choose to allocate charging slots when I'm on solar.
The indication is that if I charge on solar all day, I will no longer get the cheap rate at night on Go.
Any idea?
Never charge on Solar, let solar charge any batteries for nothing, instead pay back into the grid @15p/kWh and buy overnight at 7p/kWh.
You have to admit though, when we signed up for solar panels & FiT, nobody had EVs, power diverters or batteries to use 100% of it.
It's only fair!
Unless you are on FiT, get paid 23p (in my case) and use it to charge, don't pay 7p overnight.
I'm not fully understanding why you would want to charge an EV during the day using solar power if you are being paid a FiT (feed in tariff) of 23p/kWh to feed power into the grid!!
Surely a decent overnight cheap tariff to buy electricity in @7p (Octopus Intelligent Go) and sell back to the grid @ 23p/kWh during sunny periods makes good financial sense.
I'm a more recent Solar convert (DIY by the way) and receiving 15p/kWh. one of my neighbours is getting 60p Fit, but their solar panels are very early and poor efficiency compared to my 600W monocrystalline panels at over 20% efficiency.
On FiT you get paid to generate and a deemed 50% export however little you actually export.
I believe with FIT you get paid the contract amount for generation, the fact that you use it yourself is of no consequence, you still get paid the 23p/kWh.
I believe with FIT you get paid the contract amount for generation, the fact that you use it yourself is of no consequence, you still get paid the 23p kWh.
Now that makes better sense John @johnb80 , we have to constantly read between the lines on this type of forum due to people not fully explaining what they are trying to say, or perhaps not reading back what they write :ROFLMAO:(y):)
In this case my neighbour should perhaps buy an EV, they are on an original feed in tariff of close to 55p per kWh, I wonder if they would still get the tariff if they upgraded their panels to achieve a better efficiency and up their feed in rate?
