Back windows washing system
zagreus
Ikast, Denmark
HS PHEV
My pump you can here it is starter and the tank is filled full up.
But there isn't coming anything to back windows
It is working for the front windows anyone have this experience
Check the washer is not blocked by any thing, you will find it where the arm comes out. If you run out of fluid you may have a air lock, how long did you run it for.
Now check the outlet to make sure it’s not blocked you find under the black cover between the blade arm and black cover, it is at the 12 o’clock position. If you can get some one to run the washer and listen to see if you can hear air coming out of the hole
When you run the washer check under the car to see if any water is running out also check the boot lid when open as a pipe may have come off. Not sure if it’s a one or two motor system.
Is there a different sound between the motor when you wash the windscreen then the back window.
Ok
if you have time would you let me know the outcome please.
Your local garage can do a reverse blow with their air line they have a dedicated nozzle for your situation
Had the same issue, took it to dealers, the hose had come loose and they had to refit it
