- Oct 29, 2023
- Location
- Christchurch, NZ
- MG4 SE SR
I'm not complaining about the offset of the temperature reading, it is inconvenient, but that's it, or the range drop with the AC on, that's pretty much already covered in other threads. However during a recent trip (the first long one with the MG4), I have noticed the heater is not quite as smooth as it is expected nowadays. I managed to set the temperature to 26 degrees, which is about 3 degrees higher than I usually do in my recent cars. Fan speed on 2, just to keep the mist off from the windscreen and to get some airflow to the cabin. It was fine for awhile, we felt the temperature rising reasonably quick, and become comfortable. Suddenly it decided it was too much, so started to cool the cabin. I mean the air blown in the cabin, was pretty much freezing cold. Then the cabin temperature dropped, and the heater started to heat again. The temperature differential could be around 15-20 degrees (the blown air), which was very unpleasant.
Not sure whether it is the "normal MG4" way to control cabin temperature, or should I get it checked by the dealer?
