The problem here is that you don't know how good the quality of these second hand cables really are ?.if the charger has a lead built in then I think k it will work , ive not tried any other chargers .
when I plugged in the granny charger the battery in car was showing 36% and to.charge it to 100% it was going to take 17 hrs .
I was looking on ebay at cables and they are ones from land rover, porch and other makes , would these do? there about £40 used .
Any type2 to type2 single phase 32A will workif the charger has a lead built in then I think k it will work , ive not tried any other chargers .
I played around with lead i have , it says 33amp.on it and I noticed the right side top pin is pushed in on the pod port end (unknown if its ment to be loke this , just seeing tip.of.it and shorter.that rest )The problem here is that you don't know how good the quality of these second hand cables really are ?.
You could end up right back where where you started.
EV's are not cheap, so why risk using a used one on your pride and joy.
The Granny lead gains it name from the fact that it is a bit slower in its pace / speed.
The cable has to be rated as 7kw 32amp, you can buy a 3.5kw 16amp cable but it will reduce the charging rate by about 50%.
I will try again tomorrow at different post , it was a free post i usedI would suggest that you try another post at a different location and you are still struggling on getting the charge to commence, or the speed is less than 7 kw's, then its a trip to the dealers unfortunately.
The will use the MG lap top to check for any charging issues and update the software first.
A third party EV garage can check the car for codes etc, but they will not be able to apply any updates to the car.
