Charger gone on a go slow
LDN21
London
I have noticed that my ZS (2020) has suddenly gone on a charging go slow. There has been no changes with the car or with the charger used (PodPoint 7kw in private residential parking what I only have use of)
Previously it was charging fine (low to full in a few hours) however the last two charges have only put about 30% on in about 10+ hours significantly less.
My question is what order should I look into it. The three possible areas I have identified are: PodPoint (need to talk to managing agent and May result in it being turned off for months again), Car (recently had to do factory reset due to issues with MGPliot), Cable (no change)
I would go to my closest tesco and use their 7kW charger and see if you experience the same. This would eliminate the car.
Probably the charger IMO.
I've noticed, a couple of times on my local Tesco PodPoints that if another car plugs in to the same post, the rate drops to around 3kW, not always though. It has happened once with my ZS and a couple of times with SWMBO's 5.
Yes, in my local Tesco also see this happen, but I thought OP had a Podpoint at home, either way try another charger a few around you don't need to charge it fully if you just want to check the rate of charge.
