thedomg
Hoping someone can tell me what rookie mistake I am making.
Pulled in to a Gridserve 120kw rapid this evening. Pressed 'P'.
Powered off.
Walked to front, opened flap & removed bungs.
Selected CCS on the charger, tapped payment card (accepted!), plugged cable in.
Charger said 'Connected', I hit OK.
It tried to start charging, took ages, then said "Charging error. Communication problems. Make sure the car is turned off then retry."
So, I unplugged, replaced bungs, closed flap, locked the car. Unlocked, got in and power cycled it (on, wait til ready, off). Got out and repeated as above EXCEPT, before I hit OK, I locked the car.
Charge started successfully.
Do you have to lock the car before it'll start charging? What if you want to sit in it while it charges? What if you want to leave kids/dogs/unfed dry gremlins in it?
What's the right process here?
Powered off.
