Default Settings
Niki94d
Farington, Lancashire
MG5
Is it possible or has anyone figured out how to change any of the default settings?
1. Eco instead of normal driving
2. KERS value
3. Speed assist/limiter always turns off.
Also has anyone figured out how the "follow me home" lights work? I have the setting turned on but when I lock the car no lights are on.
That's all in the Owner's Handbook :confused:
Do you not have one?
Sorry, didn't realise that was what you meant.
You can't change the defaults. They are fixed.
Thought that might have been the case but thought I would ask.
Have you managed to get the follow me home head lights working? I've got it turned on but nothing happens when getting out the car/locking
Are you following this? :
Follow Me Home
After the START/STOP Switch is turned off, pull the light
lever towards the steering wheel. This will enable the
Follow Me Home function, dipped beam headlamps and
side lamps will illuminate depending upon the vehicle
configuration. For some models, it can be set in the
"Comfort and Convenience" in "Vehicle" settings on the
entertainment display.
Follow Me Home
Just tried and all working thanks. Must of missed this when reading the book
