Disappearing Time & Temperature from screen
jdavies414
Durham
This information has simply disappeared. Minor issue, but nuisance nevertheless.
Car is MG EV (delivered Nov 2020).
Reluctant to do a factory reset in case of unintended consequences.
Any one else had this issue?
Whatever you do, DON'T do a factory reset.
It will probably sort itself if the car is powered down and left for a while but if that doesn't fix it, you can try rebooting the infotainment unit or doing a 12V battery disconnect.
I take it there's still no known fix for getting stuck in Fahrenheit?
Any news on a Fahrenheit fix, my infotainment display decided to have a hissy fit and has rebooted with Temp on dash display in Deg F which is a right pain.
Factory reset dies not solve it.
Really odd this, as practically nowhere in the world uses Fahrenheit anymore other than the U.S and a few other odd outliers in none of which this car is on sale.
More so bearing in mind this is the default setting.
I don't really take any notice of it now as It displays correctly on the infotainment unit itself.
Mine the other day shown no time or temperature and the infotainment screen was unresponsive... After I parked, switched it off and on again it went back to normal.
Never heard of it switching to Fahrenheit, can you not change it back within settings?
