Display time discrepancies
When I checked the time clock in my car his morning, it was reporting 1 hour out.
It had not automatically updated.
Went into the settings in the head unit and reset the time clock manually, to the correct time of day.
When checking the settings, it was already set up to automatically update the time clock, but clearly it had not done it, for some odd reason ?.
I was in the settings, because I wanted to adjust the start and finish times, in order to take full advantage of our 5 hour cheaper rate off peak tariff.
It was the same in my previous VAG car.
I had to set the clock manually, even though it was set up to automatically do it ?.
I will check it again in the morning, just in case it decides to update itself late ?.
When adjusting the time in the head unit, it makes the same time changes in the dash panel.
I don’t want the car charging outside of the 5 hour cheap rate tariff, because it is very expensive !.
If you have not used your car today, make sure the time clock has updated !.
Had same problem. Went into settings. Turned Auto off then back on and it updated dashboard clock
