Chrisd
I fitted an OBD Bluetooth dongle to use with ABRP. The video I watched suggested that it should be taken off when not in use,as it makes the cars vulnerable to hacking.
Any thoughts?
Any thoughts?
If it's powered up when the car's locked, then I'd be thinking about the 12v battery usage... Dunno about hacking probabilitiesI fitted an OBD Bluetooth dongle to use with ABRP. The video I watched suggested that it should be taken off when not in use,as it makes the cars vulnerable to hacking.
Any thoughts?
I do (leave a dongle plugged in all the time). ZS Mk1. I watch the auxiliary battery voltage and occasionally charge it with an external battery charger, especially if I notice it under 12.0V.
I usually only take note of the auxiliary battery when under load*, e.g. pumping the tyres via my 4A pump. So that's not quite so dire.At 12.0 volts your battery is considered to be fully discharged or 'flat'
While technically true, its not easy and requires a level of sophistication that your average car thief doesn't have. As others have pointed out power draw "could" be an issue, as they have to be unswitched and they can actually take a 4A draw would you know. Depending on the current draw from the device I would probably leave it in, I used to use an OBD bluetooth dongle on an old ICE car and never had any battery problems on that.it makes the cars vulnerable to hacking.
Absolutley, remember Bluetooth LE devices (like Tile for example) can last up to 12 months on a single watch battery, so power drain shouldnt be an issue at all!I do (leave a dongle plugged in all the time). ZS Mk1. I watch the auxiliary battery voltage and occasionally charge it with an external battery charger, especially if I notice it under 12.0V. It's an LE (Low Energy) type, which probably helps.
