Door Mirrors not opening
Stuart46
AB32 6PA
HS PHEV
My October 2024 New HS PHEV has driven with no faults for the last 10 months, but now the Wing Mirrors are not opening when I unlock the car. I have checked that the setting is On and also set it to Off and back to On, but with no success.
Does anyone know how to resolve the problem. I don't want to drive to the MG dealer without wing mirrors, if at all possible.
Any help would be most appreciated.
When happens when you press the 'wing mirror' open/close button?
Thank You for your reply. Nothing happens when I press the button (ignition on), which led me to try the windows and again nothing happens.
I had looked up the fuse for the wing mirrors (F93 - 10A) and can also find the fuses for the 2 rear windows and the front passenger window (F71 and F80 - both 30A), but not the driver's window. However, I now think there is a more significant problem as I can't believe that all those fuses have simultaneously blown. Also, the front fuse box cover can't be removed without removing the large piece of trim than runs right round the front of the engine bay.
Had my MG HS Hybrid nearly three weeks now and sometimes when I open the car and get in and switch the start up button on Ive noticed once or twice the wing mirrors havent auto opened and if I press the open button they will open....its only happened a couple of times so will have to monitor it...
