I've hooked it up a 12V charger now. Hopefully it'll work. But it's such a faff.Can you hook up a 12V battery charger to it or are you out and about?
I have never used the release lever but reading other reports no one has said that it needs to be pulled hard. Have you tried pulling at different angles?
How hard does one need to pull on the emergency release cable to unlock the charge port?
I just cant seem to be able to release it?
The car is dead, I suspect a 12V battery drain.
Ah damn. it'll be a long day for me then. I've got a 1.5a charger connected to the battery at the moment.I think you will need to get juice to the 12v to get the flap open,
Yeah I think the HV will charge the 12v. I'm not sure on the jump starting though. I've read sometimes it can blow out the fuses (it was on the kia forums, so may not apply to the MGs).I think i am right in saying if you can get the car jump started the HV will charge the 12v.
Ah okay. I'll check with my neighbours when they're home and see if I can jump start.I am happy to be corrected but I believe you can jump start an EV the same way you can a petrol car. All you are doing is providing 12v from another source. I have a portable battery pack left over from when I had a car with dodgy electrics. I keep this in the car but have not needed yet. Touch wood.
I have heard people suggest the 12v that comes with the car is cheap but no idea if this is true or not.
By the sounds of the day you have the "why" will be for another day lolAh okay. I'll check with my neighbours when they're home and see if I can jump start.
As to why the 12V battery got depleted overnight remains a mystery to me.
Thanks!This is from my FL model manual
Really really hard. I had to do this on Saturday when it wouldn't unlock from a charger at the supermarket. I was surprised at how hard I had to pull the release cable.How hard does one need to pull on the emergency release cable to unlock the charge port?
At least you have identified that the 12v is shagged. A nice shines new battery will be good.Right okay. So are the updates.
Tried tickle charging overnight. Didn't help the battery.
But managed to jump start using a donor vehicle.
The car sprung to life. Lots of errors on the dash (lane keep, ACC, etc). But the 12v battery showed 14.5v so that's good.
Tried opening the charging port, no luck.
Locked and unlocked the car, waited a few seconds, tried the charging port, no luck.
Turned the car off, tried to turn the car again and it wouldn't start. Checked the 12v battery using a multi meter (it's showing 6V).
So 12V battery that came with the car seems to be dead. Will try jump starting again once the rain stops.
But my bigger problem is the charge port flap not opening. It's never happened before. I've pushed on the MG logo, pushed where the lock is (to the right of the MG logo), but no luck.
Has anyone had to replace their 12V?
That 14.5V will be the charger output, not the battery voltage.The car sprung to life. Lots of errors on the dash (lane keep, ACC, etc). But the 12v battery showed 14.5v so that's good.
As for the flap someone did mention above it looked like it is not closed fully. Did you try pushing it towards the car to try and get it closed fully?
When I first got my car I had an issue with the flap getting stuck not fully closed. What happened was I unlocked the car went round to the flap and as I was opening the car auto locked as I had not opened any of the doors after unlocking it. The flap got stuck not fully closed.
I had to lock / unlock the car and gently giggle the flap to get it to open.
Not sure if this helps.
To get the true reading of the battery you would need to do this when the car is off. When the car is on it is sending charge to the battery to charge it. This will give a false reading.Yeah I tried pushing on the flap. No luck. Also tried pushing it and holding it in. Then locking and unlocking the car. No luck.
Ah my bad. I thought that was the 12v battery voltage. Using the multimeter I've measured the voltage of the battery when the car is on (after jump starting it the second time). And it's 14.50V which is consistent with display on the car.
