bimbamboodle
Literally, how do we charge the car? Have the cable connected from car to charger but it’s not charging! Please send help! And feel free to laugh!
Make sure timer is switched off on the car and limit is not set a a low % by accidentIt’s at home, a Rolec wall pod charging unit.
How can we check if the timer is switched on if we can’t bind the car to the app please?Make sure timer is switched off on the car and limit is not set a a low % by accident
You can do it all by flicking the battery switch takes you to battery optionsHow can we check if the timer is switched on if we can’t bind the car to the app please?
Yes! He had it set to charge from midnight via the app which he now can’t access! So by going through the touchscreen he’s changed the times to ‘anytime’ for charging. Found that by charging overnight was cheaper but made the daytime costs far more expensive and not worth the ‘saving’.Any luck?
