I drive down to Wales from London fairly regularly (174 miles door to door). Did it today in 7° weather, arriving with 18% SOC and 36 miles of range left.I've never done a comparison but intuitively I'd say ACC was less efficient.
Depends how you drive, but @Alb and @EvTek23 have explained it pretty well.Can anyone shed any light on whether it is more or less officient to use ACC, especially for a longish (over 100 miles) journey?
Why? I'd say the opposite*.I've never done a comparison but intuitively I'd say ACC was less efficient.
I think Alb feels that the ACC is too jerky to beat a human driver aiming for low energy consumption, even on the models (hopefully all recent models) that use regen to correct over-speed when ACC is active.Why? I'd say the opposite
*However I have an MG4 and regen absolutely is performed when using ACC and going downhill or slowing.
For energy to be "recovered" you'd need to see the power meter go -ve.There is the theory too that low or no regen should be used on a long journey as the power used to regain speed if you overly slow by taking your foot off the accelerator would be more than what had been recovered during the slowing. With no regen the car obviously slows much less so takes less power to regain speed.
If you go down a steep hill on ACC it will go negative.For energy to be "recovered" you'd need to see the power meter go -ve.
How often does thus happen? For me only when I intentionally slow.
If you can be accurate enough with the throttle the mode shouldn't make a massive difference.However with max regen there is likely to be a less stable speed than with no regen.
But I'll be sticking with OPD unless I really really need to hypermile
The early ZS EVs (pre hybrid and pre face lift) don't regen with ACC. The power meter just stops dead at zero, and doesn't go negative, until you cancel ACC, then regular regen allows for negative acceleration. Speed is controlled by friction braking only, when ACC is active.If you go down a steep hill on ACC it will
Apologies, I was thinking of our MG4.The early ZS EVs (pre hybrid and pre face lift) don't regen with ACC. The power meter just stops dead at zero, and doesn't go negative, until you cancel ACC, then regular regen allows for negative acceleration. Speed is controlled by friction braking only, when ACC is active.
I still own one (the blue half of my avatar).
Definitely not having regen in ACC, mine was also second generation ZSI'll have to double check but I was sure my Gen2 ZS also doesn't regen on ACC
I checked mine once and it showed no regen at all on ACC, mine is also second generation ZS EV, 2022 Trophy standard range ...Mine is a ZS EV 2nd gen also and it does mean you get better efficiency with ACC off as you get regen
I don't think that's universally true John. I've noticed no advantage in NOT using ACC. On long runs it's definitely more frugal with battery power when you are cruising long distances. In those circumstances the need to lift off the throttle just isn't there so regen has no purpose anyway. If driving without cruise engaged your foot makes constant adjustments on the accelerator, sometimes without you even realising it. Uses more power quite often. The adjustments that cruise makes when cruising are tiny by comparison to what we as drivers do, unless going uphill. But you as a driver would have to do similar anyway.Mine is a ZS EV 2nd gen also and it does mean you get better efficiency with ACC off as you get regen
