Good morning MG fellows, I am planning to travel from Doncaster to Bulgaria, where I am originally from, and back next summer driving our MG5. Just wondering if anyone else has done a Euro trip before, would share some tips and advice on how to make the journey smooth and easy.
Thank you in advance.
I'd get yourself a Shell Recharge/New Motion RFID. It's a bit pricey but it has good compatibility across Europe. Also look at a ChargePoint card as they also have good cross network access.
You may want to get a Euro plug to granny lead extension cable:
Tough Leads products are renowned on EV forums and Facebook groups for their high quality and reliability. Please see our article on safely charging electric vehicles for advice on extension leads. It is the responsibility of the EV user to consider the manufacturers guidance, the safety of the...
Find EV charging stations with PlugShare, the most complete map of electric vehicle charging stations in the world!Charging tips reviews and photos from the EV community.
Register on everything, add your address & cards before you go. Some you need to do 3 months before to get your RFID and get your details sorted. Have a print out of what works where so no panic on the day
When you do long distances ignore the GOM and instead use the actual miles per kw and percentage.
Starting the day at 100% you have 80% of the range to charger 1 that allows backup in case of issues. After that you allow 60% of range (20-80% charge) thereon.
If you have loads of chargers you can do 120 km/hr if they are sparse slow down to 100 km/hr. Rain impacts on range so slow down.
Some networks are dire or busy, others have multiple chargers & are reliable, the comments on those map links will help you and check whilst at the previous charger.
If you arrive & they're dead, check the emergency stop button, often you just twist & they pop out putting the charging station back in action.
This chap is an expert and did much of what you want to do in a 24kw Nissan van when chargers were rare.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
