EV mode problem
Blarter
west midlands
HS PHEV
Had the car about 1month, 73 model, will not engage EV mode until I have been driving for 10mins, then it keeps dropping back to auto, it’s not cold weather, my heater is only on setting 1. Any advice ?
What's the charge level on your battery?
I have exactly the same issue with my PHEV. I get the on-screen message "EV Mode Entry not Support(ed?)" when I try to engage EV Mode.
The traction battery is fine - I am reading 50km range. Any ideas before I bring it back to the garage for them to have a look at it? Is there some setting that I have inadvertently set?
Thanks
As an update on the above, I brought the car to my MG garage and, after two visits, this issue is now resolved - but not by the garage I hasten to add. They advised me that it might be because one of the spark plugs is gone or that, because the heating system needed the ICE to fire up, it was not allowing EV mode.
After some experimentation, it seems that all the elements of the heating system (air, seats, windows) demand power from the traction battery and, if the demand is high enough, then the ICE fires up to protect the traction battery, regardless of the remaining battery charge level. This continues for some time during which EV mode is not supported and you get the message I was getting above. However, after some time running in ICE mode, it seems that the batter recovers sufficiently to allow you to go into EV mode - always if you reduce the heating demand (turn down the temp sufficiently, for example) or sometimes even if you don't reduce anything. I assume the latter case is where one or more of the heating elements happens to be off on a thermostatic cycle at the time you switch to EV mode. Finally, this thermostatic arrangement probably explains why the car drops our of EV mode sometimes of its own volition, without me changing anything.
This is my new understanding and may or may not be accurate but, either way, it perfectly explains the behaviour of the car is all circumstances with respect to the ICE/EV mode set-up and I am now using it to maximise my EV driving hours without going insane trying to figure what is going on with the car. A win-win, I feel.
As a rider to the above, when the car came out of the garage, the mirrors no longer folded in when the car is locked. I checked the setting on screen and it was still set to close automatically on locking. I unset and reset it several times but still the mirrors won't fold. I know this is the subject of much debate elsewhere in this space so won't labour the point here.
