Well, that's 3 years with 17600 miles on the car and it just passed it's 1st MOT with Red immediate attention items as follows,
Front brake pads
Front brake disc corroded
Rear brake pads
Rear brake discs corroded
I assume the brake pads are because of the grooves worn around the discs. Not a good sign for a low mileage 3 year old car.
I honestly thought it would fail due to grooved discs. These are NOT covered by the 7 year warranty.
I have also noticed the front drivers side seat base at the side of the base has started to split, so not such hard wearing vinyl after all. Even 10 year old Fords I've owned didn't do that.
I have also discovered the rear wheel arch interior plastic covers (both sides) are split, looks like the seatbelt buckle got stuck when the seat back was pushed back up and this is the outcome. I don't think I did it but can't be certain.
Battery fully charged and equalised at -6c temperature shows full range of 140miles.
I know the range in cold weather is reduced quite a bit so hopefully range will improve in the summer.
I still like the car but I am now getting a bit wary about it's longevity.
Front brake pads
Rear brake pads
