Front Fog Lights
biffo
Rutherglen, South Lanarkshire
I never use them, in fact replaced them with Osram DRL units on my Ford, but has anyone fitted front fog lights? Guess they could be wired to work on the rear fog light switch?
Additional picture of saloon but front end looks the same - https://shopee.ph/MG-5-2020--Front-Fog-Lamps-i.53515690.7055192114
I hardly ever used them on cars I've had, headlights have always been good enough in most instances.
Not sure if you can legally connect to the rear fogs though. :unsure:
You're probably right - all cars I've had them on have been two switches. Only used front fogs when younger to look 'cool' ?
I just thought the MG5 looked pretty with those in place!!
I installed these ...
The switch next to the kers button could come in handy if installing fog lights :unsure:
Where did you wire these into? Are they additional DRL and a fog light?
I used the harness next to the headlamps. All wiring on the left one next to the battery apart from the turn right indicator wire which went into the right!
They are a DRL which change to a strobing / rolling arrow amber indicator when relevant and I wired the round lamp to the main beam as couldn't be bothered to find a way of making them a front fog light.
