Going camping - how to keep my beer cool?
quilkin
Truro, UK
I'm planning a camping trip with tent etc. I'd hoped to buy a simple 12V coolbox to plug into the car. But now find there's no 12V socket in the boot. I could buy an extension lead and plug it under the dash - but I assume that won't be powered while the car is switched off (e.g. overnight). So if I buy a coolbox with mains option, I can use the V2L cable to power it from mains when I'm parked up (I'll be using V2L for cooking and lighting my tent anyway). Seems a bit of a faff to have to keep moving it though - I'd rather just store the coolbox in the boot all the time. Suggestions? Thanks
I got an extension lead for mine that runs from the front, between the seats and through the gap in the split rear seat. Halfords I think.
I have recently bought a BougeRV CRPRO 20 L compressor fridge/freezer, capable of going down to -20 degrees if needed. The interesting point with this is that it has a compartment to take a battery which can be bought from them as a package so that it becomes a self contained unit. The fridge draws no more power than a peltier cool box, has normal or eco modes so only draws 36W in eco and 45W in normal, but unlike a peltier coolbox it is not continuous. It has built in battery protection with 3 preset thresholds. The battery which fits into a compartment in the top has an accessory socket output, a USB A output and a USB C dual direction port, and a built in torch. As well as the USB C port for charging the battery there is a DC power connector with cable supplied to charge from a car accessory socket, although this might need extending if your socket is at the front of the car. The battery supports simultaneous charge and discharge with a readouts for both. So it will power the fridge and charge when the car is powered up. The battery has a capacity of 277Wh or 15Ah. Mine came from BougeRV themselves, UK store, but Amazon also have them, so there might be a better deal at one or the other at the moment.
The only drawbacks are price compared to a coolbox if bought as a package with battery, and in my MG4 when it is installed in the boot it tended to block out radio (dab/fm) reception. I have found however that if its covered with several aluminium lined normal cool bags this screens it enough to make reception almost normal except in the weakest areas.
The 12v plug lead on ours is long enough to reach from the front socket to the boot so may be worth checking before you buy an extension lead. Also check to see if you can run it off a power bank such as your 12v battery booster if you have one.
If V2L is active, the DC/DC (14V) is also operational even when the car is switched off, therefore a 12V extension into the boot seems the easiest solution?
Just bear in mind that if the V2L stops for any reason in the middle of the night, you may end up with a flat 12V aux in the morning. Bring a battery starter with you just in case…
I'd get and extension for so you can keep in cool on the road but switch to V2L once you are there. The car is quite good at looking after itself when using V2L but I'm not so sure that it will handle the 12V so well when parked up.
Not sure using V2L overnight would be feasible unless the adaptor is lockable and waterproof and you have a route into the car for the cable.
A DIY waterproofing of the connector, not particularly elegant but effective.
Nice idea that rubber sheet! I would not use electrical tape though, it's not waterproof, or at least it doesn't stay that way.
Invest in some 'self amalgamating tape' which is rubber tape that you stretch and wrap, when it shrinks back it's properly waterproof. A 5 meter (unstretched) roll is about a fiver but it goes a long long way.
The adaptor locks itself in place like the charging cable. I haven't used mine in the rain but I have left it plugged in for a couple of days while camping last year.
I just remembered seeing this some time back a review of an Amazon product by Toms Man Shed. It is reasonably priced so maybe not worth going DIY. He does waffle on a bit (a lot) so you could just start at 8:24 for the demo. Link to the product and the Youtube video below.
That sounds interesting, if a little pricey - and quite big? But does it solve the V2L / 12V supply switchover issue?
If you are buying beer which has to be cold, you are buying the wrong beer !!!
HaHa! Normally I'd agree with you. But it's over 30 deg here in France and that's a bit warm for any beer.
Thanks for all the other replies. I may be missing something but I don't really see how the waterproofing ideas solve the problem of getting the V2L power back into a closed car. And because the V2L appears to turn itself off every time the car is opened, it would be a real pain anyway.
I'm managing to work things OK by moving the coolbox into the tent (mostly) and using V2L when I'm staying at a site, and running from the internal 12V socket while driving.
I say 'mostly' because the box only goes down to 18deg below ambient. In the car (or in the tent) when its 30+ degrees outside it's much hotter inside. So I have to move the coolbox during the day to a shady spot away from the tent. Still on V2L.
But a problem has arisen, the V2L turns off every time I open a car door, I'll start a hew thread about that.
