Granny charging first
I did this the whole time I owned a Leaf (the most it could charge at was 3.3Kw, so it wasn't that much slower on the granny) - No major issues except for when I used a double socket and boiled a kettle on the other side.... Melting plastic..... not good!! :rolleyes::ROFLMAO:
The 'granny' only pulls 2.2kw, not sure how you didn't blow a fuse pulling 3.3kw?
No, the granny was only pulling 2.2 - I meant that the onboard charger, with a 'proper' chargepoint could only do 3.3 - so not a huge uplift - which was a main contributor to my decision to not bother installing a wallbox. When the battery is only 24kwh it only took 10h to fully charge anyway - so all was good!
Anyways, I'm currently nursing a 23 year old dinosaur until my new ZS arrive. The main issue with my current car is having dodgy air-con in Portugal is no fun at all at the moment (cue violins...)!!
