johnb80
- May 22, 2023
- Location
- Gainsborough, Lincolnshire
- MG5
I’m currently away on holiday in Wales. In preparation I tried granny charging via a good quality 10 metre extension lead. The lead was the thickest I could find commercially available but was only 1.5 mm2. After 8 hours of charging at 1.8 kW (max), the lead was warm and the plug and socket at either end. Definitely safe enough but I didn’t like it.
I made up an extension lead with 2.5 mm2 arctic cable with a rubber plug and single socket.
Granny charging with this lead gave a higher rate of charge on the same granny charger, no heating of the cable / plugs / sockets. Many 13 amp plugs have a max cable size of 1.5 mm2, I drilled mine out for the 2.5 mm2 flex, all worked out really well
