Corindikev
- Sep 20, 2023
- Location
- Gulmarrad, NSW, Australia
- MG4
This is from Mitsubishi in Australia but I note there have been new developments specifically by both Misubishi and Toshiba in Finland with specially developed cold climate air sourced heat pumps with a heat coefficient of performance (COP) above 2.0 at temperatures as low as -20c and between 1.5 & 2.0 for the Mitsubishi at -30 deg C.Not sure where you're getting your info from but as a Finn, I can tell you with confidence that there are ASHP's that work well to heat a home even at -25C temps and colder (efficiency does drop but they still work).
Coming in from the cold: Heat pump efficiency at low temperatures
So you are quite correct but I do not think this latest development will have made its way into EVs yet
