Douglas
I have a zs ev and it's 7 months old turned on the heater for first time yesterday it doesn't matter how high I set the thermostat it only blows tepid air not hot or very hot, I wonder if anyone else have had this problem.
Ok thanks I will try thatIf you have it in ECO mode, it’s restricts the heat available in the cabin.
Put the car in normal mode and try that .
Ok thanks yes in Eco mode, Mk2Are you in Eco mode? What model? Mk1 in particular had faulty resistor in the heater switch. Many had it sorted under warranty.
Thanks I will try that not mentioned in hand book does it apply to cooling as wellSelect normal or sports mode and you will nice a toasty in the cabin .
The cabin heater is a hungry beast regards range, so in Eco mode it is designed to reduce heat to the cabin to preserve range.
Thanks your a star works perfectly in normal even local Mg garage didn't know when I spoke to them this morning, once again many thanks.Thanks I will try that not mentioned in hand book does it apply to cooling as well
