Help Please! [ re: Damaged rear light glass ]
Raystr
UK
Hi Everyone, I have just put a hole in my rear nearside light cover with a bloody brush handle (I kid you not) it has cracked the outer red plastic reflector but the actual lighting is in tact. There are two lights in question, one on the actual tail gate (which is fine) and the other on the side, which is the one in question. Does anybody know if this red reflector cover is sold seperately, or will I need to buy the whole assembly? Also, anyone know where I can get one please? MG ZS Exclusive 2020. You should have seen the look on our lasses face - Priceless!
Plenty of ZS EV's being broken for spares on EBay.
I have a feeling you will require the complete rear light cluster sorry ?.
The Gen2 model has LED rear lights, if I remember correctly, the Gen1 model is running on standard bulbs ??.
Here is video showing how you get the light cluster out !.
Thank you so much, really helpful!
You could have ended up with the broom handle somewhere else!
Depending on how tight of a git you are money wise, that other option might even be better for someone.
Atleast if it made a hole or damage to "a hole" that would be free to have repaired :)
I think this is what you require ?,
Double check the part number first, from
the part number on your cluster maybe ?,
Or, ring a local dealer for a part number and also do a price check before ordering this one, as it is not cheap !.
Krikey - Thank you so much - it looks spot on! I might message em! it is a bit expensive but they might take less..... strange mate, I looked at Ebay and found nothing - Thanks again for looking for me!
There seems to be a few on Ebay a bit cheaper at around £60.
No problem, just check on the dealer price first !.
