The Gen1 ZS EV TPMS pressures read around the 2.4 bar mark from memory, which sounds like about 35 PSI to me and the tyres are a 50 profile of the side wall.
The new Gen2 ZS EV is fitted with a slightly taller 55 side wall profile.
Taller profile tends to mean a more forgiving ride.
Extremely low profile tyres on the other hand have very little “Give” in the side wall when travelling over a rough / choppy road surface.
Great on grip and handling in the dry, but a harsh ride.
Nightmare in the snow !.
Sorry, back to the face lift tyres pressures, if it recommended to have them set at 41 PSI then that is around the 2.8 bar at a rough guess ????.
So, a 6 PSI ( ish ) increase over the original tyre pressures on the Gen1 model then?.
The facelift with the long range pack is also packing a bit more weight than the Gen1 version of the ZS EV.
These points may go someway to explain why the increase in tyre wall profile, plus the increase in the tyre pressures across both Gen1 and a Gen2 models ?????.
Increasing the tyre pressures will slightly help the efficiency returns of the car.
Manufactures who MPG test their ICE cars ( in a controlled environment ) will try every trick in the book to inflate the return figures.
That includes over inflating the tyres, which is only one trick
